overall_header_content_before viewtopic_topic_title_beforeviewtopic_topic_title_prependSUMP VALVEviewtopic_topic_title_append
viewtopic_topic_title_after viewtopic_body_poll_before viewtopic_body_poll_after viewtopic_body_postrow_post_before- viewtopic_body_post_author_before Pandit viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
SUMP VALVE
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_before-Welche Funktion hat das Sump Valve und was passiert, wenn es offen bleibt?
Vielen Dank für eure Hilfe.
Re: SUMP VALVE
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforebis1937 sollte es ( das sumpfventil ) im system bleiben .
schönes schrauben, arne
Re: SUMP VALVE
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeDanke für die Antwort.
Vielen Dank
Roland
Re: SUMP VALVE
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeGruss Roland
Re: SUMP VALVE
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeHallo Roland,Pandit wrote:.....Der Scraper ist einfach die offene Leitung mit der Leitung ins Gehäuse?......
Arne wrote:.....er ist aber nur bei zerlegtem motor ein, bzw. anzupassen.....
Re: SUMP VALVE
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeTrotzdem zur Sicherheit: Wenn dass Öl "abgekratzt" wird, läuft es dann in die offene Leitung zur Rücklaufpumpe?
