viewtopic_topic_title_prependÖlverlust 741viewtopic_topic_title_append
viewtopic_topic_title_after viewtopic_body_poll_before viewtopic_body_poll_after viewtopic_body_postrow_post_before- viewtopic_body_post_author_before hornli73 viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Fri 19. Sep 2014, 12:55 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
Ölverlust 741
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_before- Attachments
Re: Ölverlust 741
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforemit dem Foto anhängen hat es wohl nicht geklappt, ich kann es jedenfalls nicht finden.
Re: Ölverlust 741
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeDie Stelle ist mit einer Dichtung versehen. Indian Factory Number: 40821
Grüße, Thorsten
Re: Ölverlust 741
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeSorry war vorher ein bisschen zu gross gruss ErnstMat wrote:Hallo Ernst,
Re: Ölverlust 741
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeHallo Thorsten danke für die Antwort hoffe das man das Loch Abdichten darf mal schauen was die Experten meinen.Danke und gruss ErnstAli wrote:Hallo Ernst,
Grüße, Thorsten
Re: Ölverlust 741
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforedas Loch dient nur dazu, bei der Demontage des Getriebes einen Dorn hineinzustecken um damit die Achse des Tannenbaums (Vorgelegewelle) auszutreiben. Wie es verschlossen wird ist für die Funktion unerheblich.
Re: Ölverlust 741
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeHallo Rafy besten Dank für den Tip Ölstand passt werde das mit dem Rundholz machen, so macht Schrauben Spass!! vielen Dank ErnstRafy wrote:Hallo Ernst,
