overall_header_content_before viewtopic_topic_title_beforeviewtopic_topic_title_prependZylinder Hohnen Sport Scout 741 JG 1941viewtopic_topic_title_append
viewtopic_topic_title_after viewtopic_body_poll_before viewtopic_body_poll_after viewtopic_body_postrow_post_before- viewtopic_body_post_author_before hornli73 viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Fri 19. Sep 2014, 12:55 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeFrage 1 kann der Originalzylinder überhaupt gehohnt werden?
Frage 2 gibt es passende Kolben zum kaufen und wo?
Danke im voraus Ernst
- viewtopic_body_post_author_before HansDKW viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Sun 21. Feb 2010, 20:46 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
Re: Zylinder Hohnen Sport Scout 741 JG 1941
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforefragst Du ueber Sport Scout, oder 741 Zylinder?
Gruess
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_before741 Sport Scout jahrgang 1941.Gruss ErnstHansDKW wrote:Hallo,
Gruess
- viewtopic_body_post_author_before Indianrider viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Wed 26. Jun 2013, 21:13 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeEntweder es ist eine 741 mit 500ccm oder eine Sportscout mit 750ccm.
741 Sportscout gibt es nicht.
Gruss Jens
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforevon der Größe der Bohrung kann es eigendlich nur ein Thirty-Fifty oder eine 741 sein.
Nenne doch mal die Anfangsbuchstaben der Motornummer.
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeEine 741 mit 493ccm aber vom Kolbenmass her kann es kein Standardtkolben sein daher suche ich Kolben komplett mit Durchmesser 66.7 oder 66.8 dass der Zylinder nur gehohnt werden muss will in nicht auf 68.5 Frässen lassen.Indianrider wrote:Moin,
Gruss Jens
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeHallo Ali hab den Motor zurzeit nicht zuhause Fahrgestell Nr.GDA 16929Ali wrote:Moin,
Gruss Ernst
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeim Original fängt die Fahrgestellnummer mit der Modellbezeichnung an. In Deinem Fall sollte es die 741 sein.
Einer Deiner Vorbesitzer hat dann wohl die Motornummer in den Rahmen gestanzt.
Viele 741 Fahrer haben die Zylinder auf 70mm gebohrt und Fahren damit problemlos. Jürgen Mattern hat Kolben von 68 bis 68,5mm im Angebot.
Falls die Laufflächen in den Zylindern noch gut sind könntest Du über eine Beschichtung deiner alten Kolben nachdenken. Vorausgesetzt das diese noch in einen dafür brauchbaren Zustand sind. Mehr Infos dazu gibt es bei den Firmen die beschichten.
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeDanke Dir mit dem Jürgen habe ich schon gemailt der hat leider nur noch 68,5mm warte jetz noch auf ein Angebot vom PETE aus GB mal schauen was der noch im Keller hat danke dir trotzdem für deine Bemühungen und ein schönes Indiend Gruss ErnstAli wrote:Hallo Ernst,
