diese habe ich gemeint, mit umlaufenden Schellen....
Gruss
Robert
EV EVHi Stefan ,101.rainer wrote:Hi Stefan,
Rainer Zimmermann
Post by gringo-brd »
EV EVPost by gringo-brd »
EV EVPowered by phpBB® Forum Software © phpBB Limited
Powered byTime: 0.308s | Peak Memory Usage: 15.53 MiB | GZIP: Off | Queries: 22
PHP Event | Count | Since | Filename (line) |
core.common | 1 | 3.1.0-a1 | common.php (171) |
core.session_ip_after | 1 | 3.1.10-RC1 | phpbb/session.php (303) |
core.session_set_custom_ban | 1 | 3.1.3-RC1 | phpbb/session.php (1256) |
core.viewtopic_modify_forum_id | 1 | 3.2.5-RC1 | viewtopic.php (277) |
core.phpbb_content_visibility_is_visible | 1 | 3.2.2-RC1 | phpbb/content_visibility.php (172) |
core.phpbb_content_visibility_get_visibility_sql_before | 2 | 3.1.4-RC1 | phpbb/content_visibility.php (213) |
core.user_setup | 1 | 3.1.0-a1 | phpbb/user.php (232) |
core.user_setup_after | 1 | 3.1.6-RC1 | phpbb/user.php (357) |
core.viewtopic_before_f_read_check | 1 | 3.1.3-RC1 | viewtopic.php (395) |
core.viewtopic_gen_sort_selects_before | 1 | 3.2.8-RC1 | viewtopic.php (485) |
core.gen_sort_selects_after | 1 | 3.1.9-RC1 | includes/functions_content.php (143) |
core.append_sid | 90 | 3.1.0-a1 | includes/functions.php (1543) |
core.viewtopic_highlight_modify | 1 | 3.1.11-RC1 | viewtopic.php (576) |
core.viewtopic_add_quickmod_option_before | 1 | 3.1.9-RC1 | viewtopic.php (696) |
core.modify_text_for_display_before | 16 | 3.1.0-a1 | includes/functions_content.php (598) |
core.text_formatter_s9e_renderer_setup | 1 | 3.2.0-a1 | phpbb/textformatter/s9e/renderer.php (117) |
core.text_formatter_s9e_render_before | 16 | 3.2.0-a1 | phpbb/textformatter/s9e/renderer.php (248) |
core.text_formatter_s9e_render_after | 16 | 3.2.0-a1 | phpbb/textformatter/s9e/renderer.php (265) |
core.modify_text_for_display_after | 16 | 3.1.0-a1 | includes/functions_content.php (669) |
core.generate_forum_nav | 1 | 3.1.5-RC1 | includes/functions_display.php (839) |
core.viewtopic_assign_template_vars_before | 1 | 3.1.0-RC4 | viewtopic.php (775) |
core.pagination_generate_page_link | 3 | 3.1.0-RC5 | phpbb/pagination.php (84) |
core.modify_username_string | 36 | 3.1.0-a1 | includes/functions_content.php (1653) |
core.bump_topic_allowed_before | 1 | 3.3.14-RC1 | includes/functions_content.php (312) |
core.viewtopic_modify_post_list_sql | 1 | 3.2.4-RC1 | viewtopic.php (1246) |
core.viewtopic_get_post_data | 1 | 3.1.0-a1 | viewtopic.php (1320) |
core.viewtopic_post_rowset_data | 8 | 3.1.0-a1 | viewtopic.php (1399) |
core.user_format_date_override | 16 | 3.2.1-RC1 | phpbb/user.php (635) |
core.get_avatar_after | 7 | 3.1.6-RC1 | includes/functions.php (3780) |
core.viewtopic_cache_user_data | 6 | 3.1.0-a1 | viewtopic.php (1514) |
core.modify_user_rank | 6 | 3.1.0-RC4 | includes/functions_display.php (1519) |
core.get_user_rank_after | 6 | 3.1.11-RC1 | includes/functions_display.php (1568) |
core.grab_profile_fields_data | 1 | 3.1.0-b3 | phpbb/profilefields/manager.php (403) |
core.viewtopic_modify_post_data | 1 | 3.1.0-RC3 | viewtopic.php (1737) |
core.generate_profile_fields_template_data_before | 8 | 3.1.0-b3 | phpbb/profilefields/manager.php (456) |
core.generate_profile_fields_template_data | 8 | 3.1.0-b3 | phpbb/profilefields/manager.php (530) |
core.viewtopic_modify_post_action_conditions | 8 | 3.1.0-b4 | viewtopic.php (1977) |
core.viewtopic_modify_post_row | 8 | 3.1.0-a1 | viewtopic.php (2155) |
core.viewtopic_post_row_after | 8 | 3.1.0-a3 | viewtopic.php (2252) |
core.viewtopic_modify_page_title | 1 | 3.1.0-a1 | viewtopic.php (2416) |
core.page_header | 1 | 3.1.0-a1 | includes/functions.php (3818) |
core.update_session_after | 1 | 3.1.6-RC1 | phpbb/session.php (1753) |
core.obtain_users_online_string_before_modify | 1 | 3.1.10-RC1 | includes/functions.php (3519) |
core.obtain_users_online_string_modify | 1 | 3.1.4-RC1 | includes/functions.php (3579) |
core.add_form_key | 1 | 3.1.0-RC3 | includes/functions.php (2072) |
core.page_header_after | 1 | 3.1.0-b3 | includes/functions.php (4187) |
core.make_jumpbox_modify_forum_list | 1 | 3.1.10-RC1 | includes/functions_content.php (186) |
core.make_jumpbox_modify_tpl_ary | 18 | 3.1.10-RC1 | includes/functions_content.php (262) |
core.page_footer | 1 | 3.1.0-a1 | includes/functions.php (4308)
core.phpbb_generate_debug_output | 1 | 3.1.0-RC3 | includes/functions.php (4279) |
core.twig_environment_render_template_before | 2 | 3.2.1-RC1 | phpbb/template/twig/environment.php (220) |
core.twig_environment_render_template_after | 1 | 3.2.1-RC1 | phpbb/template/twig/environment.php (237) |
core.page_footer_after | 1 | 3.1.0-RC5 | includes/functions.php (4330)
bool | return |
bool | banned |
array|false | ban_row |
string | ban_triggered_by |
string | forum_id |
array | topic_data |
bool | is_visible |
string | mode |
int | forum_id |
array | data |
string | where_sql |
string | mode |
array | forum_id |
string | table_alias |
mixed | get_visibility_sql_overwrite |
array | user_data |
string | user_lang_name |
string | user_date_format |
string | user_timezone |
mixed | lang_set |
array | lang_set_ext |
mixed | style_id |
int | forum_id |
int | topic_id |
int | post_id |
bool | overrides_f_read_check |
bool | overrides_forum_password_check |
array | topic_tracking_info |
array | limit_days |
array | sort_by_text |
array | sort_by_sql |
array | join_user_sql |
int | sort_days |
string | sort_key |
string | sort_dir |
string | s_limit_days |
string | s_sort_key |
string | s_sort_dir |
string | u_sort_param |
int | limit_days |
int | sort_days |
string | sort_key |
string | sort_dir |
bool | def_st |
bool | def_sk |
bool | def_sd |
array | sorts |
string | url |
mixed | params |
bool | is_amp |
bool|string | session_id |
bool|string | append_sid_overwrite |
bool | is_route |
string | highlight |
string | highlight_match |
int | start |
int | total_posts |
string | viewtopic_url |
int | forum_id |
int | post_id |
array | quickmod_array |
int | topic_id |
bool | allow_change_type |
string | text |
string | uid |
string | bitfield |
int | flags |
bool | censor_text |
\phpbb\textformatter\s9e\renderer | renderer |
string | xml |
string | html |
string | text |
string | uid |
string | bitfield |
int | flags |
array | forum_data |
array | forum_template_data |
string | microdata_attr |
array | navlinks_parents |
array | navlinks |
string | base_url |
int | forum_id |
int | post_id |
int | start |
int | topic_id |
int | total_posts |
string|array | base_url |
string | on_page |
string | start_name |
int | per_page |
bool|string | generate_page_link_override |
string | mode |
int | user_id |
string | username |
string | username_colour |
string | guest_username |
string | custom_profile_url |
string | username_string |
array | _profile_cache |
int | forum_id |
int | topic_bumped |
int | last_post_time |
int | topic_poster |
int | last_topic_poster |
string | sql |
int | sql_limit |
int | sql_start |
string | sort_key |
string | sort_days |
int | forum_id |
int | forum_id |
int | topic_id |
array | post_list |
int | sort_days |
string | sort_key |
string | sort_dir |
int | start |
array | sql_ary |
array | rowset_data |
array | row |
DateTimeZone | utc |
array | function_arguments |
string | format_date_override |
array | row |
string | alt |
bool | ignore_config |
array | avatar_data |
string | html |
array | user_cache_data |
int | poster_id |
array | row |
array | user_data |
int | user_posts |
array | user_data |
int | user_posts |
array | user_rank_data |
array | user_ids |
array | field_data |
int | forum_id |
int | topic_id |
array | post_list |
array | rowset |
array | user_cache |
int | start |
int | sort_days |
string | sort_key |
string | sort_dir |
bool | display_notice |
bool | has_approved_attachments |
array | attachments |
array | permanently_banned_users |
array | can_receive_pm_list |
array | profile_row |
array | tpl_fields |
bool | use_contact_fields |
array | row |
bool | force_edit_allowed |
bool | s_cannot_edit |
bool | s_cannot_edit_locked |
bool | s_cannot_edit_time |
bool | force_delete_allowed |
bool | s_cannot_delete |
bool | s_cannot_delete_lastpost |
bool | s_cannot_delete_locked |
bool | s_cannot_delete_time |
bool | force_softdelete_allowed |
int | start |
int | current_row_number |
int | end |
int | total_posts |
int | poster_id |
array | row |
array | cp_row |
array | user_poster_data |
array | post_row |
array | post_edit_list |
int | start |
int | end |
int | total_posts |
array | row |
array | cp_row |
array | post_row |
string | page_title |
int | forum_id |
int | start |
array | post_list |
bool | display_online_list |
string | item |
int | item_id |
bool | page_header_override |
array | session_data |
array | online_users |
int | item_id |
string | item |
array | rowset |
array | user_online_link |
int | item_id |
string | item |
array | rowset |
string | online_userlist |
string | l_online_users |
string | form_name |
int | now |
string | s_fields |
string | token |
string | token_sid |
string | template_variable_suffix |
string | item |
int | item_id |
array | http_headers |
array | rowset |
array | row |
array | tpl_ary |
bool | run_cron |
bool | page_footer_override |
array | debug_info |
array | context |
string | name |
array | context |
string | name |
string | output |
bool | display_template |
bool | exit_handler |
