viewtopic_topic_title_prependGabel Chief 1936viewtopic_topic_title_append
viewtopic_topic_title_after viewtopic_body_poll_before viewtopic_body_poll_after viewtopic_body_postrow_post_before- viewtopic_body_post_author_before tortoloco viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Fri 20. Aug 2010, 12:30 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
Gabel Chief 1936
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeDie Feder ist von Jerry Greer,die Hilfsgabeln haben einen Lochabstand von 45cm.
Bitte auf die Stellung der Rocker achten.
- Attachments
Re: Gabel Chief 1936
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_before- Attachments
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeGruß
- viewtopic_body_post_author_before roadmaster50 viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Tue 1. Feb 2011, 16:35 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeJemand aus dem Indian Riders Motocycle Club England hat sich intensiv mit der Problematik der Blattfedergabeln auseinander gesetzt. Den Artikel findest Du hier:
Auf der Seite des Clubs dann weiter zum Menüpunkt "Technical", und dann den Artikel "Indian Chief Leaf-Spring Forks - Andy Donald" auswählen.
Ist ein recht detailierter Artikel, und wer weiss vielleicht hilft er Dir weiter.
Gruss: roadmaster50
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeIch habe den Lochabstand bei meiner 41er Chief gemessen: 48 cm. So nehme ich an, du hast die richtigen Rocker Arm Studs.
Kann es sein, dass die Blattfeder falsch montiert ist und gekehrt mehr nach oben zeigen würde?
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_befoream Thema vorbei.
Grüße Torsten
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_before- viewtopic_body_post_author_before Mat viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeOder richtig herrichten lassen, Gerd Brummer hat seine 45er Gabel von John Hillebrandt instand setzen lassen und ist sehr zufrieden.
