Page 1 of 1
Umbau Autolite Lima von 3 Kohlen auf 2 Kohlen
Posted: Sat 3. Jan 2015, 15:57
by mslala
Posted: Sat 10. Jan 2015, 20:27
by Martin
Hallo mslala,
Ist das so?
eine 12 Volt Ausführung.
09561-54533, abends.
Martin.
Posted: Sat 24. Jan 2015, 17:35
by scouty
http://www.splitdorfreg.com/Autolite%20 ... lation.htm
LG,
Posted: Mon 19. Jul 2021, 18:48
by Harley-B
