Dicht ! Und wieder Besuch in der Garage.
EV EVPost by 101.rainer »
EV EVHi Thomas,FLH75 wrote:
Post by roadmaster50 »
| core.append_sid | 85 | 3.1.0-a1 | includes/functions.php (1543) |
| core.modify_text_for_display_before | 14 | 3.1.0-a1 | includes/functions_content.php (598) |
| core.text_formatter_s9e_render_before | 14 | 3.2.0-a1 | phpbb/textformatter/s9e/renderer.php (248) |
| core.text_formatter_s9e_render_after | 14 | 3.2.0-a1 | phpbb/textformatter/s9e/renderer.php (265) |
| core.modify_text_for_display_after | 14 | 3.1.0-a1 | includes/functions_content.php (669) |
| core.modify_username_string | 31 | 3.1.0-a1 | includes/functions_content.php (1653) |
| core.user_format_date_override | 15 | 3.2.1-RC1 | phpbb/user.php (635) |
| core.get_avatar_after | 6 | 3.1.6-RC1 | includes/functions.php (3780) |
| core.viewtopic_cache_user_data | 5 | 3.1.0-a1 | viewtopic.php (1514) |
| core.modify_user_rank | 5 | 3.1.0-RC4 | includes/functions_display.php (1519) |
| core.get_user_rank_after | 5 | 3.1.11-RC1 | includes/functions_display.php (1568) |
