overall_header_content_before viewtopic_topic_title_beforeviewtopic_topic_title_prependUmbau Autolite Lima von 3 Kohlen auf 2 Kohlenviewtopic_topic_title_append
viewtopic_topic_title_after viewtopic_body_poll_before viewtopic_body_poll_after viewtopic_body_postrow_post_before- viewtopic_body_post_author_before mslala viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Mon 23. Dec 2013, 21:22 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_before- viewtopic_body_post_author_before Martin viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeGAS 4151 deutet darauf hin dass es sich hier um eine CHIEF handelt, Baujahr zwischen 1940 - 1946.
Ist das so?
eine 12 Volt Ausführung.
09561-54533, abends.
Martin.
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_before viewtopic_body_postrow_content_after viewtopic_body_postrow_post_notices_before viewtopic_body_postrow_post_notices_after viewtopic_body_postrow_signature_before viewtopic_body_postrow_signature_after viewtopic_body_postrow_post_content_footer- viewtopic_body_post_author_before Harley-B viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Wed 9. Jul 2014, 12:27 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
