overall_header_content_before viewtopic_topic_title_beforeviewtopic_topic_title_prependSuche Werkstatt oder Mechanickerviewtopic_topic_title_append
viewtopic_topic_title_after viewtopic_body_poll_before viewtopic_body_poll_after viewtopic_body_postrow_post_before- viewtopic_body_post_author_before G.bauermeister viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Sat 4. Aug 2012, 18:51 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_before- viewtopic_body_post_author_before schwälmer viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Sun 2. Mar 2014, 18:40 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
Re: Suche Werkstatt oder Mechanicker
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeund herzlichen Glückwunsch zur 741. Bist du ne Runde gefahren?
Gruß Andreas
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeHeute wird erstmal das saisonkennzeichen abgeholt .
Bisher hab ich sie nur in der Garage schnurren lassen
GB
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeGruß Andreas
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeWar bei mir genauso . Ich hab sie von einem Polen optisch super gekauft. Nach 200 km ist mir der Motor um die Ohren geflogen. Inzwischen kann man sagen das es Technisch absoluter Schrott war was ich gekauft habe . Von den Polen Kisten sind gleich 3 Stück nach Deutschland gegangen.
Deswegen setzte mal ein Bild von deiner rein !
Gruß Andreas
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeleg doch mal bei stehendem Motor den Gang ein, tret die Kupplung und versuche zu schieben. Wenn das geht, dann trennt die Kupplung. Einlegen des ersten Gangs, besonders bei kaltem Getriebe macht immer Krach. Da darf man nicht zimperlich sein. Einfach mit Schwung den Gang einlegen. Allzu vorsichtiges Einlegen bringt keine Schonung. Wenn die Kupplung wirklich nicht trennt, kannst Du hinten am Kupplungsgestänge den Bolzen zum Hebel rausziehen und nach Lösen der Kontermutter die Gabel ein oder zwei Umdrehungen weiter auf das Gestänge drehen. Vielleicht trennt sie dann.
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeDamit meine ich (erst mal) keine Motor und Getriebeüberholungen, aber zumindest die Wartungsarbeiten wie Kupplung, Zündung, Ventile und Vergaser einstellen, Ölwechsel, lose Schrauben nachziehen, abschmieren usw sollte man schon selbst durchführen können.
Wenn Du wegen jeder Kleinigkeit zum Profi-Schrauber musst, wird auf Dauer nur Frust aufkommen.
Und Du kannst Dir, wenn Du mit dem Mopped unterwegs bist und Probleme auftauchen, nicht helfen...
- viewtopic_body_post_author_before blueharro viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Fri 16. Jan 2015, 19:58 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforewenn du noch Besitzer deiner 741 bist, könnten wir uns in der nähe von Eschwege oder Göttingen mal treffen. Hier in ESW sind auch zwei 741 Fahrer und wir könnten dir ein paar Tricks und Tips für deine Indian geben!!
Indian Grüße Jörg
