overall_header_content_before viewtopic_topic_title_beforeviewtopic_topic_title_prependBatterie 6 Volt Fourviewtopic_topic_title_append
viewtopic_topic_title_after viewtopic_body_poll_before viewtopic_body_poll_after viewtopic_body_postrow_post_before- viewtopic_body_post_author_before mslala viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Mon 23. Dec 2013, 21:22 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_before- viewtopic_body_post_author_before Ali viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
Re: Batterie 6 Volt Four
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforedieser hier sollte passen: Blei-Vlies-Akku, 6 Volt, 4,5 Ah, 102x70x48mm
Wenn Dir die 4,5Ah nicht ausreichen passen sogar zwei hinein. Wenn Du die parallel schaltest hast Du 9Ah.
Von CTM (Typ CT 5-6) gibt es die sogar mit 5Ah.
Solltest Du eigentlich in jeden Batterieladen bekommen.
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforewie Conrad o.ä. die haben Akkus in allen Varianten.
