Habe mal einen ersten kleinen Bericht in meinen Blog gestellt. Werde ein Repro Gehäuse aus Down Under verwenden (müssen).
http://americancycles.blogspot.de/2016/ ... e-101.html
EV EVPost by bobberfred »
| core.append_sid | 88 | 3.1.0-a1 | includes/functions.php (1543) |
| core.modify_text_for_display_before | 16 | 3.1.0-a1 | includes/functions_content.php (598) |
| core.text_formatter_s9e_render_before | 16 | 3.2.0-a1 | phpbb/textformatter/s9e/renderer.php (248) |
| core.text_formatter_s9e_render_after | 16 | 3.2.0-a1 | phpbb/textformatter/s9e/renderer.php (265) |
| core.modify_text_for_display_after | 16 | 3.1.0-a1 | includes/functions_content.php (669) |
| core.modify_username_string | 36 | 3.1.0-a1 | includes/functions_content.php (1653) |
| core.viewtopic_post_rowset_data | 9 | 3.1.0-a1 | viewtopic.php (1399) |
| core.user_format_date_override | 18 | 3.2.1-RC1 | phpbb/user.php (635) |
| core.get_avatar_after | 7 | 3.1.6-RC1 | includes/functions.php (3780) |
| core.viewtopic_cache_user_data | 6 | 3.1.0-a1 | viewtopic.php (1514) |
| core.modify_user_rank | 6 | 3.1.0-RC4 | includes/functions_display.php (1519) |
| core.get_user_rank_after | 6 | 3.1.11-RC1 | includes/functions_display.php (1568) |
| core.generate_profile_fields_template_data_before | 9 | 3.1.0-b3 | phpbb/profilefields/manager.php (456) |
| core.generate_profile_fields_template_data | 9 | 3.1.0-b3 | phpbb/profilefields/manager.php (530) |
| core.viewtopic_modify_post_action_conditions | 9 | 3.1.0-b4 | viewtopic.php (1977) |
| core.viewtopic_modify_post_row | 9 | 3.1.0-a1 | viewtopic.php (2155) |
| core.viewtopic_post_row_after | 9 | 3.1.0-a3 | viewtopic.php (2252) |
