Youtube video: http://www.youtube.com/watch?v=3OxvBi6Au8k
These Fords are in a seperate building, I estimate he has at least 150 Model A Fords in here
| core.append_sid | 57 | 3.1.0-a1 | includes/functions.php (1543) |
| core.text_formatter_s9e_configure_before | 1 | 3.2.0-a1 | phpbb/textformatter/s9e/factory.php (214) |
| core.text_formatter_s9e_configure_after | 1 | 3.2.0-a1 | phpbb/textformatter/s9e/factory.php (375) |
| core.text_formatter_s9e_configure_finalize | 1 | 3.2.2-RC1 | phpbb/textformatter/s9e/factory.php (407) |
| Configurator | configurator |
Modify the s9e\TextFormatter configurator before
the default settings are set
Modify the s9e\TextFormatter configurator after
| array | objects |
Access the objects returned by finalize() before
they are saved to cache
