Suche eine Halterung für die DU7 an die 402
Danke schon mal...
| core.append_sid | 70 | 3.1.0-a1 | includes/functions.php (1543) |
| core.modify_username_string | 17 | 3.1.0-a1 | includes/functions_content.php (1653) |
| core.obtain_users_online_string_sql | 1 | 3.1.4-RC1 | includes/functions.php (3474) |
Modify SQL query to obtain online users data
Changes: 3.1.7-RC1
