viewtopic_topic_title_prependOberfläche Zylinderviewtopic_topic_title_append
viewtopic_topic_title_after viewtopic_body_poll_before viewtopic_body_poll_after viewtopic_body_postrow_post_before- viewtopic_body_post_author_before Pandit viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
Oberfläche Zylinder
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeVielen Dank für die Hilfe.
Re: Oberfläche Zylinder
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeIch empfehle die Zylinder matt oder chemisch vernickeln zu lassen. Hab hierzu gerade einen interessanten Link gefunden:
Mfg,
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeHast du sowas schon mal machen lassen?
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeGruss Roland
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeGruß
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeich hab vor Jahren die Zylindern meiner 1941er Chief galvanisch glanzvernickeln lassen. Das hat ganz gut geklappt. Je tiefer die "Kühlrippen-Spalten" allerdings sind, desto geringer ist die Nickelschicht beim galvanischen vernickeln - je nachdem wie das Nickel-Becken eingestellt ist und wie viel Zeit der Vernickler in die individuelle Bearbeitung deiner Teile inverstiert, kann dieser Effekt aber verringert werden.
Die Zylinder sollten zum vernickeln auf jeden Fall gründlich gereinigt/entfettet und eventuell auch gestralt sein - es sollten keine Ölkohle-Reste und Lackreste auf und im Zylinder sein.
Eine Glasperl-gestrahlte ode fein Sadgestrahlte Oberfläche hat auch den Vorteil, dass der Nickel auf eine homogene Oberfläche aufgetragen wird und je nach Rauheit der Fläche auch ein gewisser Mattierungseffekt der Nickelschicht eintritt.
Beim strahlen auch darauf achten, dass das Strahlgut zur Gänze entfernt wird und vorallem zwischen den Kühlrippen, dass das Strahlgut dort nicht an eingebrannten Schmutz- und Ölresten festklebt (die mit dem strahlen nur schwer zu entfernen sind und durch das festklebende Strahlgut nachher kaum zu erkennen sind - also am besten vorher grob mit einem Schaber, Schraubenzieher oder selbst gebauten Hilfsmitteln diese Öl-Schmutzschickten entfernen).
Ob Nickelreste am Zylinder sind spielt im Normalfall keine Rolle, da die Teile vor dem Nickelbad abgelaugt/entnickelt werden.
Wie und ob die Bohrungen an deinen Zylindern vorbeiretet werden sollen ist einerseits von der Art der Venickelung aber auch vom derzeitigen Bearbeitungsstand der Teile abhängig. Details holst du dir hier am besten vom Betrieb, bei dem du die Vernickelung machen läßt.
Ideal ist sicher, wenn du alte Ventilführungen eingepreßt läßt und die Zylinder noch nicht bearbeitet hast.
Wenn du die Bohrungen schließt, musst du auf jeden Fall besprechen wie die Nickelbad-Lösungen aus den Bohrungen abfließen können und gleich nach dem vernickeln die Verschlüsse entfernen damit die Hohlräume nicht rosten.....
Soweit meine Erfahrung. Ich bin kein Galvanik-Profi, aber in den Grundzügen sollten meine Tips schon stimmen. Wenn dem nicht so ist bitte ich um andere Meinungen - freue mich immer wenn ich was dazulernen kann!
LG,
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_before1. sich der Aufwand nur "lohnt", wenn der ganze Zylinder überarbeitet werden muss.
2. mein Bike nicht fürs "Judging", sondern fürs Fahren gemacht wird.
3. Kostet es auch noch was (und nicht gerade wenig)...
