viewtopic_topic_title_prependLichtmaschinenregler defekt, oder was anderes?viewtopic_topic_title_append
viewtopic_topic_title_after viewtopic_body_poll_before viewtopic_body_poll_after viewtopic_body_postrow_post_before- viewtopic_body_post_author_before Rainer viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Sat 6. Feb 2010, 10:08 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeich habe seit einiger Zeit Stromprobleme mit meiner 46er Chief.
So langer Text.
Danke für Rückmeldungen
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforehier ein Tip vom Rainer aus Lichtenwald.
- viewtopic_body_post_author_before Hecker101 viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Mon 2. Jul 2012, 13:36 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_before101.rainer wrote:Hallo Rainer,
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeSchau dir mal deine Verkabelung an. Wenn irgend wo ein Kurzschluß, Massfehler, oder eingebrochenes oder eingeklemmtes Kabel ist, lädt sich die Batterie auch nicht. Speziel an den Kabelschuhen die verlötet wurden ist nach ein paar Jahren durch die Säure im Lötzinn das kabel aboxidiert.
Guggst du.
Jürgen
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforejetzt bin ich nach geraumer Zeit dazu gekommen durchzumessen.
Moped aus: 12,09V
Leerlauf: 12,2V
höhere Drehzahl: 13,2V
Do moan i, laaft irgendwo da Strom naus.
Was mein ihr?
Danke für eure Rückmeldungen.
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforechecke mal deine Kabelanschlüsse am Regler und an der Lima.
- viewtopic_body_post_author_before PapaFlo viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Thu 10. Sep 2015, 20:39 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeich würde das Zündschloß mal Prüfen. Nicht das du da bei den Kontakten einen Fehler hast.
Grüße Florian
