overall_header_content_before viewtopic_topic_title_beforeviewtopic_topic_title_prependTiefbettfelgen INDIAN ab wann ?viewtopic_topic_title_append
viewtopic_topic_title_after viewtopic_body_poll_before viewtopic_body_poll_after viewtopic_body_postrow_post_before- viewtopic_body_post_author_before TOLU=TRAPP 2016 viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Tue 18. Oct 2016, 16:53 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeWeiss jemand,wann genau zum erstenmal bei INDIAN,keine Wulstfelgen mehr verwendet wurden ?
gruss Karl-Heinz
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeMeine ehemalige, im Originalzustand erhaltene 1928er 101:
https://books.google.de/books?id=ZdXaa3 ... er&f=false
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeallein aus Sicherheitsgründen würde ich dir von den Wulstfelgen abraten.
Wenn Sie nur in der Ausstellung steht , dann gerne.
Bis demnächst.
- viewtopic_body_post_author_before Harley-B viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Wed 9. Jul 2014, 12:27 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_before- viewtopic_body_post_author_before TOLU=TRAPP 2016 viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforevielen Dank für eure Antworten-------also ich denke schon,daß man beim richtigen umgehen mit Original Wulstfelgen und neuen Reifen-auch fahren kann.
Die Antworten haben mir geholfen,danke
Gruß Karl Heinz
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeda hätte ich gerne originale Verkaufsunterlagen aus 1928 dazu - sonst glau ich es nicht. Die frühen 1929er 101s hatten noch Wulsträder - 18" Drahtfelgen kamen Mitte 1929 - so ist es aus zahlreichen originalen Unterlagen ersichtlich und ich hab auch schon einige sehr originale Maschinen gehabt bzw. genauer angesehen.
19" Drahtfelgen wurden auf den Motorrädern gene nachgerüstet, da die Reifen sicherer und die passenden Wulstreifen nach dem Krieg bis in die 80er Jahre nicht leicht erhältlich waren.
101 Scouts hatten ab Werk 18" Räder (Wulst oder Draht) - mit 19x4.00 wird es in den Kotflügeln auch schon sehr eng.
19" war ab Werk den Chiefs vorbehalten (bzw. 27x3.85 Wulst ab 1925)
LG,
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforegruss karl-heinz
