overall_header_content_before viewtopic_topic_title_beforeviewtopic_topic_title_prependDer teuerste Brief in dem Lebenviewtopic_topic_title_append
viewtopic_topic_title_after viewtopic_body_poll_before viewtopic_body_poll_after viewtopic_body_postrow_post_before- viewtopic_body_post_author_before mariusz viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
- Joined: Thu 7. Apr 2016, 09:42 viewtopic_body_postrow_custom_fields_before viewtopic_body_postrow_custom_fields_after viewtopic_body_contact_fields_before viewtopic_body_contact_fields_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_before viewtopic_body_postrow_content_after viewtopic_body_postrow_post_notices_before- viewtopic_body_post_author_before mariusz viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforewie kann ich am besten solche schaden reparieren?
https://lh3.googleusercontent.com/MQZth ... 42-h589-no
https://lh3.googleusercontent.com/ATnaR ... 86-h589-no
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeschade um den Zylinderkopf, die zur Zylinderkopfschraube durchblasende Kopfdichtung müsste deutlich zu hören gewesen sein. Weiterfahren in solchen Fällen killt den Kopf, weil an den undichten Stellen Temparaturspitzen auftreten, die über dem Schmelzpunkt von Alu liegen. Erfahrende Spezialisten im Aluminium-Schweißen können das hinbekommen, danach muss der Kopf neu geplant werden. Da man neue Köpfe kaufen kann, würde ich dazu raten und den kaputten Kopf als Wandschmuck nehmen.
Scout-Grüße
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeGruß
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforehttps://photos.google.com/share/AF1QipN ... 1GVGUxWWJ3
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_beforeSuch Dir einen geduldigen Schweißer.
viewtopic_body_post_buttons_list_before viewtopic_body_post_buttons_list_after viewtopic_body_postrow_post_details_before viewtopic_body_postrow_post_details_after viewtopic_body_postrow_content_before- viewtopic_body_post_author_before mariusz viewtopic_body_post_author_after viewtopic_body_postrow_rank_before viewtopic_body_postrow_rank_after
